Перебрал постпроцессор, вот что получилось:
; Beaver 26 AVST configuration file
DESCRIPTION = "Beaver26AVST (*.tap)"
FILE_EXTENSION = "tap"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 1
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.1]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Arc Center Coords
FORMAT = [I|@|I|1.3]
FORMAT = [J|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "M6T[T]"
START = "G43H[T]"
START = "M3[S]"
; Program moves
RAPID_RATE_MOVE = "G00[X][Y][Z]"
FIRST_FEED_RATE_MOVE = "G01[X][Y][Z][F]"
FEED_RATE_MOVE = "[X][Y][Z]"
FIRST_CW_ARC_MOVE = "G02[X][Y][Z][i][J][F]"
CW_ARC_MOVE = "[X][Y][i][J]"
FIRST_CCW_ARC_MOVE = "G03[X][Y][i][J][F]"
CCW_ARC_MOVE = "[X][Y][i][J]"
;Setup Toolchange Commands
TOOLCHANGE = "M05"
TOOLCHANGE = "M6T[T]"
TOOLCHANGE = "G43H[T]"
TOOLCHANGE = "M3[S]"
; End of file
END = "M05"
END = "M30"
Не совсем получилось, не хватает знаний. Нужно вот это:
M6T1
G43H1
M3S18000
G00X115.000Y95.000Z50.000
G01Z9.000F900.0
G03X211.000Y95.000I48.000J69.300F4500.0
G02X246.000Y130.000I35.000J-0.000
G01X246.000Y586.000
G02X211.000Y621.000I0.000J35.000
G03X115.000I-48.000J-69.300
G02X80.000Y586.000I-35.000J0.000
G01X80.000Y130.000
G02X115.000Y95.000I-0.000J-35.000
G00Z50.000
M05
M6T2
G43H2
M3S18000
G00X95.071Y66.228Z50.000
G01Z13.000F1200.0
G02X80.000Y95.000I19.929J28.772F6000.0
G02X45.000Y130.000I-0.000J35.000
G01X45.000Y586.000
G02X80.000Y621.000I35.000J-0.000
G02X95.071Y649.772I35.000J0.000
G02X230.929I67.929J-98.072
G02X246.000Y621.000I-19.929J-28.772
G02X281.000Y586.000I0.000J-35.000
G01Y130.000
G02X246.000Y95.000I-35.000J-0.000
G02X230.929Y66.228I-35.000J0.000
G02X95.071Y66.228I-67.929J98.072
G00Z50.000
G00X0.000Y0.000
M05
M30
А получилось вот это:
M6T1
G43H1
M3S18000
G01Z-9.000F900.0
G01X246.000Y586.000
G02X80.000Y586.000I-35.000J-0.000
G01X80.000Y130.000
G00Z50.000
M05
M6T2
G43H2
M3S18000
G01Z-13.000F6000.0
G02X80.000Y95.000I19.929J28.772F1200.0
G01X45.000Y586.000
X95.071Y649.772I35.000J-0.000
G01Y130.000
G00Z50.000
G00X0.000Y0.000
M05
M30
Основные различия: G01 Z (-) на заглубление, в эталонной программе отсутствует (-), G код распространяется на несколько строк, в строке 11, J-0.000 появился (-) в эталоне отсутствует, очень странный момент.
Помогите подогнать постпроцессор, очень близок, но понял что не по силам. ПОМОГИТЕ.
