Вы здесь » Форум клана ЧПУшников » "Комплектующие для станков с ЧПУ" » Выбор Контролера 4 axis Mach3 USB 200\400\1000Khz
4 Axis E-CUT Mach3 USB CNC Motion Controller Card Interface Breakout Board 1Mhz
http://se.uploads.ru/t/RldPk.jpg
http://se.uploads.ru/t/tyS2A.jpg
Supports all Mach3 versions, including the Mach3 R3.042.040 version.
Supporting Windows series, including the latest version of Windows7.
No need to install any USB drivers,it can be used after plugging in the computer.
Full support for USB hot-swappable, the card is Monitoring USB connection status at any time.
Supports 4 axis linkage,including point to point move
Supporting auto tool zero,electronic handwheel and software limit,return difference eliminating.
48M speed,signal is independently handled by motion control card to ensure real-time and reliability.
Maximum step-pulse frequency is 800KHz, which is suitable for the servo or stepping motor.
Status indicator LED can be useful to show the USB connection, and working status by flashing.
16 general-purpose inputs , with indicators.
Real-time spindle speed can be observed in March3.
Measures real-time speed and spindle speed can be observed in March3.
Use external 12V-24V DC power supply to isolate USB and external port,and to make the system more stable.
9 high speed optical couplers with 10MHz, 25 general optical couplers for isolating all of the
input/output signals,
the high-cost designed can be provided the safe separation distance of 2.5mm.
Accurate 0-10V analog output,reducing external device and making the spindle speed more stable
PWM output port of 5v drop-down provides PWM speed control.
The 4 layer circuit board selected high-quality devices is exquisite.
E-CUT Controller Card Weight : 118g
USB Cable : About 190CM(1.5M Support 2.0M)
Input : 24V or 5V
____________________________________________________________________________________________________________
4-Axis-USB-Controller-Card-400KHz-CNC-MACH3-Breakout-Interface-Board-Win7-8-XP
http://se.uploads.ru/HML0D.jpg
http://se.uploads.ru/Oe7oW.jpg
Input : 24V or 5V
4 оси Mach3 ЧПУ USB гладкий степпер движения контроллер карты 200 кГц
http://se.uploads.ru/rVQ2F.jpg
USB 2.0 communication interface, real-time transmission. No need to install any USB drivers and support hot swapping. Plug-and-Play like a USB flash disk. This card is compatible with all Windows system including 32 bits and 64 bits Windows 2000/XP/Vista/Windows 7.
Opto-coupling isolation all 16 inputs/8 outputs/4 axis motor outputs/spindle speed/speed test signals. Safety and reliable. Output 200 KHz step-pulse frequency and using 10 MHz high-speed optical coupling electrical isolation.
This board has a original external ratio-adjustment knob input. It is very convenient to use the knob to adjust the feed rate (F), spindle speed (S) and jog speed (Jog).
This motion card can output precision spindle speed analog: 0-5V or 0-10V. You can connect a frequency inverter to control the spindle speed. Besides, the card has a spindle speed signal input (Closed-loop threading is not supported). The Mach3 will display the pindle speed vaue in real time. And provide real-time speed graph to make the speed variations clear and lively.
More Features
Support all the Mach3 versions, including the latest edition: Mach3 R3.042.040.
No need to install any USB drivers. Plug-and-Play on all Windows system including 32bits and 64 bits Windows 2000/XP/Vista/Windows 7.
Support for USB hot swapping . To monitor USB attachment state any time. While Mach3 are working, if you uproot USB cable, then plug it also can make it work at once.
Support 4 Axis linkages. Including inching, as well as 4 shaft linkage.
Maximum output 200 KHz step-pulse frequency . Suitable for servo and stepping drivers.
There are 10 super-speed 10 MHz opto-couplers, 24 General opto-couplers, so the total amounts of opto-couplers are up to 34. Isolate all the input/output. The High costs design provides a complete anti-jamming function and perfect security protection.
Have on-board isolation power supply, NO external power supply. Simplify the requirements of electric power supply. It’s convenient to connect external power supply can also be used, so you can have any choice you like.
Support the following functions: Automatic tool-setting, electronic hand wheel, software limit, software backlash .
Speed: 48M, Real-time input signal without PC intervention , The Signal is independently processed by the Movement Control Cards. Ensure that you get really real-time information and reliability.
Have status indicator to indicate Mach3 attachment, and USB connectivity. All kinds of state are clear for you at a glance.
Have 16 input indicators. It Clearly indicates the status of signal-input.
Have Speed-measurement function , The Spindle actual speed is displayed on the Mach3 interface in real time. And provide real-time speed graph to make the speed variations clear and lively.
Applications
Suitable for all stepper and sevro drivers that driven by Step and Dir signals.
This breakout board is just a interface board, NOT a stepper driver board, it must work together with the microstep drivers(eg. MA860H etc..) to control the stepper motors. So, it CANNOT control the stepper motors solely.
какой из них выбрать не знаю у меня драйвера на 200Кгц (возможно буду увеличивать)
По цене они все примерно одинаковые хотел брать ту что 1Mгц, только вот почему не знаю больше покупают 200Кгц плату. (Цена у них почти равная хотя церцы разные)
Объясните дураку в чём тут разница?
И посоветуйте какую взять? 1Мгц лучше или хуже платы 200Кгц??
200 кгц хватит с лихвой, более вам и не потребуется если не собираетесь станок разогнать до скорости болида формулы1
Если у них цена одинаковая то лучше тогда взять 1000Кгц...  чем мощнее техника тем надёжней, тут процессор будет на 20% от номинальной мощности работать,
тогда как на 200Кгц на 100%.. и будет греться.(а значит менее надёжная и менее эфективная по КПД)
Но я так и не понял почему разницы в цене нет? Когда в герцах она есть... может там в чем то еще разница кроме герц???
