Всем привет.
Проблема такая. Есть станок с присадочной группой. Так вот для него есть два постпроцессора. Для фрезировки и для присадки. Приходится 2 раза запускать, что неудобно. Нельзя ли объединить 2 постпроцессора в один. Так же нужны программы для редактирования постпроцессора, или что обозначают все эти строки. Большое спасибо заранее.
; yiming CNC Router with SYNTEC control configuration file
; History
; Who When What
; TRB 23/08/11 Written by HADI TADJIK
DESCRIPTION = "KDT 2040 (*.cnc)"
FILE_EXTENSION = "cnc"
UNITS = mm
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 10
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 9999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.1]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.4]
FORMAT = [Y|#|Y|1.4]
FORMAT = [Z|#|Z|1.4]
; Arc Center
FORMAT = [R|@|R|1.4]
; Home tool positions
FORMAT = [XH|@|X|1.4]
FORMAT = [YH|@|Y|1.4]
FORMAT = [ZH|@|Z|1.4]
; Set up program header
START ="%"
START = "[N] G90 G49 "
START = "[N] G40 G80"
START = "[N] G54"
START = "[N] M5"
START = "[N] M7"
START = "[N] G53 Z0"
START = "[N] G90 G49"
START = "[N] G54"
START = "[N] M73"
START = "[N] T[T]"
START = "[N] M3 [S]"
START = "[N] G43 H[T]"
START = "[N] M41"
; Program moves
RAPID_RATE_MOVE = "[N] G00 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "[N] G01 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[N] [X] [Y] [Z]"
TOOLCHANGE = "[N] M05"
; Toolchange Sections
TOOLCHANGE = "[N] G80"
TOOLCHANGE = "[N] M07"
TOOLCHANGE = "[N] G53 Z0."
TOOLCHANGE = "[N] G90 G49 G80"
TOOLCHANGE = "[N] G90 G49"
TOOLCHANGE = "[N] G40 G80"
TOOLCHANGE = "[N] G54"
TOOLCHANGE = "[N] M73"
TOOLCHANGE = "[N] T[T]"
TOOLCHANGE = "[N] M3 [S]"
TOOLCHANGE = "[N] G43 H[T]"
TOOLCHANGE = "[N] M41"
; End of file
END = "[N] G80"
END = "[N] M05"
END = "[N] M07"
END = "[N] G53 Z0."
END = "[N] M05"
END = "[N] M07"
END = "[N] M46"
END = "[N] G53 Z0"
END = "[N] G53 X0 Y0"
END = "[N] M30"
вот второй
; History
; Who When What
DESCRIPTION = "KDT 2040 DRILL (*.cnc)"
UNITS = mm
; Block numbering
LINE_NUM_START = 10
; Line numbering
; Spindle Speed
; Feed Rate
; Arc Center
START ="%"
START = "[N] M131 "
START = "[N] G53"
START = "[N] G54 G90"
START = "[N] M129"
START = "[N] M123"
START = "[N] M125"
START = "[N] G53"
START = "[N] G53 G90"
START = "[N] M83"
START = "[N] M33 S7000"
START = "[N] G600 T[T]"
; Program moves
TOOLCHANGE = "[N] M7"
TOOLCHANGE = "[N] G 600 T[T]"
; End of file
END = "[N] M05"
END = "[N] M46"
END = "[N] M130"
END = "[N] M30"
END = "[N] M99"
